tony2times
- Nov 6, 2015
- Michigan
- 2015 SR VIper
Can anyone confirm that this is how the axle is supposed to be reassembled with the JT Stealth Big Wheel kit.
This is looking down from the top -
This is the first time I've ever done anything to the skid of the sled. Also does anyone have the torque specs for the axel bolts and the scissor bolt in the rail that you need to loosen to spread the rails. I want to make sure I torqued these all back appropriately.
I dont know about the JT assembly but axle bolts I always just tighten tight. The scissor bolt looks to be 45ft lbs with Loctite.
