just a little track tip...
MikeWalters
Saskatchewan
Canada
2007 Phazer
So if you ever get a track for free, like I did, just look at the clip windows first...
Are you slides actually going to fit through them when you change slides :drink:
My track is an 1.5" take off from a doo, excellent lug pattern , not a finger track. Larger block style, which is perfect for where I ride.
but the clip windows are....small! damn was that tight changing slides!!!
but a little lube and a handy-dandy dead-blow hammer and no problem.
My slides are the originals, almost worn through at the rail curve. the rest of them were still excellent. Is that the common wear point on the phazer?
yes the common spot is right where the rail bends
