Just a thought on replacing mounting bolts on the ZX2
Bradford
NB Canada
Canada
06 RS Nytro
The ZX2 cross shafts where the bolts seem to back out and break are made from a steel tube with threaded aluminum inserts at either end. I wonder if the threads could be drilled out to 3/8" and a long grade 8 bolt inserted all the way through with a nut on the other side. The trick would be finding a long bolt with the right amount of shank. Any excess thread could be cut off. Instead of using Loctite, you could install a lock nut and secure it with a pinch nut...
Thoughts??
Brad
Look at the lower sciccor shaft on a pro x polaris skid. It is the exact same bolt you are talking about. Maxdlx
I trailered my sled 70 miles this past weekend to ride. When I arrived to unload I noticed a bolt was missing. I looked closer and found the bolt was in fact broken off inside...man was I pissed.
Anyway, I thought the same thing. Here is my idea:
Drill out the aluminum to 1/2" and install 1/2" stainless steel threaded rod all the way through. Cut to length with locknuts. At least you could carry a spare in your trunk if one decided to break on the trail. Hell, the rod wouldn't even have to be stainless.
This is the second time I have had broken/missing bolts on the trail. It really pisses me off. There is no way Boivin could have "field" tested this and not found the same problem.
