birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
I know there are tons of clutck kit threads here, but the ones I've read I haven't seen anything on the Scmidt Bros. Motorsports clutch kit, seen here: http://www.schmidtbrosmotorsports.com/sr-viper-torque-monster-clutch-kits/
I have their kit on my Nytro and I'm very happy with it, so would think it would work fine on the Viper as well. Anyone tried it?
I was planning to go for Ulmer Racing's trail kit but I haven't heard back from them for weeks so not sure what's going on there, so need to start to look for alternatives.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Allen has been really busy. He will eventually get back to you. Did you try sending him a message on here?
birkebeiner
- Jul 27, 2009
- Norway
- Norway
No, just emailing.
Birkebeiner
Birkebeiner
fasteddie15x
- Jan 20, 2014
I had a Schmidt Bros clutch kit on a 2008 phazer and it worked great, so i would think there viper kit would also be good.
stingray719
http://www.ty4stroke.com/threads/clutching-on-the-cheap.129971/
And real world tests by your fellow riders on all the kits here - http://www.ty4stroke.com/threads/post-your-clutch-setup.132429/
Also, Nytro kits do not work as well on a Viper as a Viper specific kit, see link above for how the different kits worked out
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Schmidt Bros have a Viper specific kit as well. It's in the link in my first post.
stingray719
Didn't see any weights in the pic, and the single biggest problem with 2014 - 2015 Viper is the stock weight ramp (has a bump in the heel that causes over rev at take off). I have not tested there setup and it may be great but all my testing has favored flat profile weights the flatter the better. If you try them post results in the "post-your-results" thread.
That being said I have used Schmidt bros products before and liked them
09nytro
Those guys aren't to far from me , I use a lot of there products, they have raced and won on many yamahas and know there stuff so I would hesitate to get anything from them , they will help you with dialing it in to ... But it should be very close when you get it ....
Great guys to deal with .... Answer the phones all the time , if they don't they will call back that day at some point !
birkebeiner
- Jul 27, 2009
- Norway
- Norway
I'll email them to check what's in the Viper kit. Can't recall what was included in my Nytro kit, but pretty sure the weights wasn't.
Birkebeiner
Birkebeiner
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Ulmer responded and I now have Ulmer's kit in the mail on the way to me. Super excited!
I did however order the quiet clutch shims from Schmidt's. They say it will reduce the clutch rattle with 75%, but let's see. If it helps, fantastic!!
Birkebeiner
Birkebeiner
swampcat
Did Yamaha clutch always sound like paint cans rattleing ? They consider THAT normal ?Ulmer responded and I now have Ulmer's kit in the mail on the way to me. Super excited!
Birkebeiner
birkebeiner
- Jul 27, 2009
- Norway
- Norway
It's been on all three 4-strokes I've had; Vector, Nytro and Viper. Not sure whether it's the 3 cyl engine only though..?
Birkebeiner
Birkebeiner
stingray719
Bought an old rental sled Nytro mountain last week with 15k miles on it. Clutch rattled so bad I couldn't tell if rod was blown. Put in a new set of weights and it sounds as quiet as my Viper
Studroes144
Birkebeiner
On the viper, the bolts that hold in the rollers are not snugged up tight, they can't be completely tightened by design, that part is normal, and with that comes the rattling, on the apex those bolts are able to be tightened up completely so you don't get that rattle, I have a used apex primary with the 14.5mm rollers that I'm gonna give a shot this year, just gonna swap my weights and spring and see what happens.
