i just got done installing my 136 track using tracks usa extensions....the track seems very tight even at the loosest setting with the axle all the way forward...it is rather hard to spin by hand...much harder than any other sled i have extended...the measurement with some weight pulling down on track is in spec but damn it seems tooooooo tight....is it because of the tension at the front of track by the curved part of the front rails??? i know the phazers are notorious for wearing the slides at that point...but this seems too tight....would a front wheel kit help??? ideas???
LJ 452
I'm assuming the track is new as well. My 128" extension seemed tight at first as well but once I got everything adjusted and centered, it turned out about in the middle of the adjusters. The track will stretch some as well. I would just make it the best you can until you get a few miles on it. any other mods, drivers, wheels?
track was used for a few hundred miles....no other mods except clutch kit....we will see how things go...hopefully it loosens up a bit...
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
will be ok , wet will help also !
- 6K
