have you replaced the in tank fuel filters?
Phazed Out
- Mar 19, 2020
- MN
- 1984 John Deere Sprintfire 340 L/C
1984 Phazer 480
1988 Phazer 480
2000 Phazer 500
2004 RX Warrior
2005 RS RAGE
2005 RX-1 ER Limited Edition
2007 Apex ER
Okay, that makes more sense. Although, normally you shouldn’t have to give slack to the throttle cable AND plug the connectors in to each other. On my Rage I had to slack the cable but the TORS wasn’t a problem after that. I didn’t need to bypass it with the connectors.it was a TPS problem i just put some slack in the throttle line and unplugged some connectors and plugged them into themselves
yammiefan04
- Aug 31, 2020
- Fergus falls MN
- 04 RX warrior, 2008 apex mtx, 2000 sx700r
Yea if i just did the connectors it was the same thing, but i once i did the throttle cable it would only do about 35 40 after i plugged the connectors back in, once i did both it got to the power it has nowOkay, that makes more sense. Although, normally you shouldn’t have to give slack to the throttle cable AND plug the connectors in to each other. On my Rage I had to slack the cable but the TORS wasn’t a problem after that. I didn’t need to bypass it with the connectors.
yammiefan04
- Aug 31, 2020
- Fergus falls MN
No i haven't, i looked for them one time but i could not seem to find them easily, maybe i just need to drain all the fuel to see them?have you replaced the in tank fuel filters?
they are in the tank and i usually replace those through the fuel filler cap with the white plastic removed using a bent coat hanger to fish them out.
Fortress
- Dec 18, 2016
- West Canada
- 2004 RX1
When it’s dark out you can shine the flash light down in the tank and see the filter really well
RobX-1
- Coldwater, OH
I used a pickup tool similar to this. It will be tight as there isn't much slack in the line but was able to replace the two in my RX-1.
