sbot69
Was riding in UP last few days and had a knocking sound coming from my primary clutch. I cleaned the clutch real good a few weeks ago with brake cleaner. A guy I was with said I should lube rollers with comet clutch lube. Any thoughts what it is?
Could just be normal. Can you post a vide of it with sound?
stingray719
Check your belt for a chunk missing or a flat spot. Really.
09nytro
More than likely it's the roller pins , I just ground my pins down flush with clutch so when you tighten the bolt it's tight and pin doesn't move ... I'll see how that works !!!!
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
The roller pins are in a clearance fit opening.. They wont make a "clunk" noise..
sbot69
Will get a video on here in next few days.Could just be normal. Can you post a vide of it with sound?
sbot69
Will check belt and let you know what I find.Check your belt for a chunk missing or a flat spot. Really.
