Fasttrax
New to launch control. Running 270-300hp. How much PSI can I safely set it to in launch mode? Thanks
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
You can set it to whatever you want, does not mean it's going to get to that boost level. Low RPM does not make the boost like a higher RPM will.
Test it and watch your logs as to what it does. If you don't have the traction needed, you'll find traction control is worse or certainly no better than leaving on just the throttle.
Fasttrax
Thanks. My clutch engages at 3600. Have my launch set at 3300. What PSI can I expect to see on launch??You can set it to whatever you want, does not mean it's going to get to that boost level. Low RPM does not make the boost like a higher RPM will.
KnappAttack
- Feb 19, 2004
- Welch MN
Well you need to set the launch RPM higher than clutch engagement at around 3850 or more as to prevent engaging on to the belt. It depends on a lot of factors as to how much boost you'll see but It wont be much depending on how long you hold it. I don't get a pound or two. And It still blows the track away if you are WFO. I typically just use it as a bump preventer as I tickle the throttle, let off the button and slowly squeeze the flipper to limit the track spin.
Play with it and look at your logs, you will need to test to optimize it. IMO it only helps prevent bumping or red lighting on the start for run of the mill arm drop snow/trail races.
Ice dragging with max traction, then that's a different story. You want high engagement and max cackle and boost to leave the line and run the number.
NYTurbo
Higher ? Don't think so
KnappAttack
- Feb 19, 2004
- Welch MN
Well if you want the machine to bump the belt and creep on the line and red-light then go ahead and set the RPM lower than clutch engagement.
But where I come from a red-light is a loss.
If the rev limiter is lower than clutch engagement, its engaging on the belt and moving the sled. So yes, set the rev limiter higher.
NYTurbo
So say clutch engages at 4000 and your going to target higher ? Good luck
KnappAttack
- Feb 19, 2004
- Welch MN
So you set rev limit lower than 4000 if clutch engages at 4000?
Do enlighten me how that makes any sense. Maybe I've been doing it all wrong all along. This I have to hear, I've left off a button and also left off a pressure sensor on the brake line too. I might learn something here.
NYTurbo
Never set my anti lag over my engagement or your launching before you hit your target . Only common sense
Fasttrax
Hurricane Performance does say to set rev limiter about 300 RPM lower than engagement. Maybe we are talking about different launch control?So you set rev limit lower than 4000 if clutch engages at 4000?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
KnappAttack
- Feb 19, 2004
- Welch MN
Yes you are correct. I had it backwards. my fault, not sure what I was thinking. I was the backwards one. RPM limiter is set lower than engagement. Guess I shouldn't be trying to think when I've had a migraine all day. I feel like an idiot.
RPM limiter is always LOWER than engagement not higher. I knew no one wanted to red-light on purpose. I knew what I was trying to say, just had it backwards.
NYTurbo
I was starting to second guess myself. All good
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Age??
KnappAttack
- Feb 19, 2004
- Welch MN
Age??
LOL! No I hope not, just a migraine and not thinking properly. I knew at I was TRYING to say, just backwards thinking is all.
