I have had the launch control on my SW for two seasons now. I have mine setup for 300rpm below engagement and it works flawlessly for my drag racing clutch setup, if only for the intimidation factor.
The launch is only active with the gap flasher linked to the sled just like data logging. I normally don't leave my flasher plugged in and generally carry it with me.
This year because there is no drag racing in our area my clutch setup is strictly trail riding oriented and the engagement is so low the launch would be virtually useless.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Can a person get launch control without a tune ?
I would think so but better call Hurricane or TD but you will need a Gap Flasher
Precision has it built into their Cluster flash
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
Migraines SUCK, just like the vacuum from a sidewinder passing a machz, effectively removing it's decals.Yes you are correct. I had it backwards. my fault, not sure what I was thinking. I was the backwards one. RPM limiter is set lower than engagement. Guess I shouldn't be trying to think when I've had a migraine all day. I feel like an idiot.
RPM limiter is always LOWER than engagement not higher. I knew no one wanted to red-light on purpose. I knew what I was trying to say, just had it backwards.
Yes, MSD makes a product called a launch master. You will also need to buy a button. They work awesome. https://www.hurricaneperformance.ca/products/power-sports-performance/msd-launch-master-4350/Can a person get launch control without a tune ?
