h20rocket
have a 2010 nytro, left handwarmer wasn't working, had dealer install brand new RSI warmers, tried it out yesterday, same exact issue, left not working
is there a fuse or something that would cause just the left one not to work ?
Not for only one. I would guess its the wiring under the bars where it all plugs in. Follow the wring down and make sure everything is plugged in correctly.
h20rocket
how would you test for power to the handwarmer, do you need to run it above 4k on a stand, I've read somewhere that they dont turn on till your going above 4k rpm
First check to see if it has s complete circuit by testing resistance on the grip itself then I would 2 wires from the batter as test leads to see if it warms up.
You could also flip flop the connectors that feed the grips to see if the other one heats up.
Tyloooor
when I first put my RSI grips on I didn't think they were working- had my buddy who's an electrician check them out and he said they were fine...it's like the needed to break in or something, cause now they work great
They will need to be over a certain RPM to work... and under that RPM they are off. For the life of me I can not remember the RPM...LOL
h20rocket
well the right ones working and the left is still ice cold so I guess Im going fast enough
I tried setting the temp at different ranges also, didnt work
did you try switching the plugs?
Off Trail Mike
Gone Riding!
- Dec 26, 2009
- Bathurst, NB, Canada
- MTX
9300 RPM!!!!....soorry....couldn't resist...LOL
OTM
I think its around 5k
OTM
LMAO... thought it was 4000 to 5000 will give you full voltage.
Tyloooor
mine get warm just warming up the sled but don't get hot until your on the throttle
