Lets play name that hose
Freak
Spanish Fork, UT
I have a hose that I dont know what to do with. It comes out from the lower back of the motor near the stator housing. Black 3/8inch line, looks like a carb vent line. It is long enough to go to the front of the motor area. Cant figure out where this goes. Carb heat line of some sort? :( Any helps would be appreciated.
My guess is that after this game I get to play lets take off the intercooler. Hopefully not lets pull the motor. :?
I believe it's the airbox water drain line. If you have an ECP kit you can discard it. If you hunt hard enough you'll see the end of it and will be able to unhook it.
Frosty
Just pull on it hard and then throw it in the trash ........ ;)!
..........air box drain
Unless ofcourse, you decide to put the sled back to stock ( :o| )
Then you could just leave it there.
