Dukester
What kind of life can we expext fron the stock Yamaha weights and rollers?
How does that compare to the HH and HC or hammer weights and rollers?
Does anyone lube their clutch?
jtssrx
I' don't think there should be an issue with stock clutch parts holing up. I'd ckeck the bushings every 1500 to 2000 miles to make sure there good.
What do you want to lube on the clutch?
I'd say no on the lube.
Dukester
Mainly the rollers. They are smaller in diameter on the HH kit and the weights are thinner.
Yamaha is a new clutch for me.
jtssrx
Don't put any lube on the clutch and as far as roller life goes like I said the roller itself should be fine. Just watch the bushings
Dukester
Thanks for the info.
Buckeye
- Lakes Region, NH
Rollers?
I am confused about the rollers. As far as I know, HH or HC don't make rollers. Are you saying you are using different rollers in your primary? If you got new ones with your weights, they are probably Yami rollers and would have no impact on wear. As long as your clutch is balanced, the rollers should last along time and not be an issue. Jason is absolutely right no lube, it would only catch belt dust and gum things up.
LazyBastard
The rollers came with the supertune2 kit he bought from BBY.
Dukester
Thanks guys!!
The rollers came with the kit.
