wildbonz
Hi everyone. I've searched the site but haven't found what I'm looking for.
Is there a good lift out there somewhere for a 660 Grizzly?
The front is pretty straightforward, but what are people using for the back. I'm not interested in the hub flip for 1/2" extra.
I'd like a couple inches front and rear, not just bigger tires. Has anyone developed/welded/manufactured anything that won't mess up the angles and stress factors? If so, could you share and maybe post some pics please?
ranger19jn
- May 12, 2009
i dont have a lift but i know that the drivetrain is already stressed at the angle its at. you can lift it but i would also change to heavier axles to help the stress.
there is a kit on ebay every once in a while by xtreame performance i think. and high lifter makes one and gorilla axles makes one but i think its taller than your going for.
hope that helps
jeff
hope that helps
jeff
![](/styles/admin.gif)
![](/styles/vip.gif)
I put one on from Gorilla. Looks great!!
shavedheadedyamaha
- Nov 30, 2008
i also put one on from gorilla.. just a stage 1 2in and i love it.. the only thing was i had to widen it so it didnt feel so tippy.. and in that it caused a problem with my 27 swamp fox's. it was ok with the lift alone (tippy). but after widing 2in on both sides (stabile) it was rubbing pretty bad on the plastics. right where they curve around the tires.. a razor knife and all was solved.. just something to think about when your going higher..
