Lights go out intermittently
yamahunter
Pa
2011 apexse
2011 apex se all lights go out intermittently then come back on but sled stays running ! We changed rectifier n headlight relay. Lights stay off for 10 to 15 seconds n then just come back on. Headlight dash n taillight. Any ideas?
Possibly a bad grounding block within the wire harness?
swap the relays around by your left foot. my 11 does this at -25 c and lower on 1st start of the day. i figure the lighting relay has a tiny bit of moisture in it and the heat/vibrations of the motor running cause it to break loose and work properly for the rest of the day. still on stock one atm at 24000 mi and counting.
