billymx815
- Nov 17, 2009
- S. Berwick, Maine
- SXV Venom, RTX Nytro, SR Viper RTX SE
- Maine
Stupid question - can someone give me the easiest way to pull the front limiter strap down 1 position?
oldsledhead
Place a 4x4 or something under the track right where the rails curve and have someone push down on rear of the sled.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
X 2 and it goes a lot faster without the skid full of ice
Rayman5271
- Oct 3, 2009
- Northern Maine
- 2016 Yamaha SR Viper XTX SE
Get someone to stand on the back of your sled... only takes 2 mins.
NytroRtx
Which hole is the stock setting? I have a used sled and not sure if the previous owner moved it already
Rayman5271
- Oct 3, 2009
- Northern Maine
I believe 5 holes from the bottom.
What does this adjustment do?
bwwelke
The farther down you pull the straps the more ski pressure it puts on the front. Most people run it on the top hole, since we all know that the nytro doesn't need any more of that.
Ya...mine came full loose...kinda figured that....
NytroRtx
ok so i want it at least 6 from the bottom or 4 from the bottom?
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
It says in the manual which one is stock, just for future reference. And you might want to run it on the second hole down from the top. So still loose but not so much ski lift. Made a big difference for me and can still pull the front end up at will if wanted.
NytroRtx
thanks
GT03235
billymx815 said:Stupid question - can someone give me the easiest way to pull the front limiter strap down 1 position?
The easiest way i find for me is as follows.
I lift the back of the sled up to put a small car floor jack under the front of the skid then just lift up a few inchs and you will have all the wiggle room with the limiter strap you need
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- Maine
Thanks for the tutorial guys
