Firecat_Freak
I'm still trying to dial in the Apex a bit better. Without hanging my whole body off the side in turns I will exaggerated ski lift. My front shocks springs are as light as they can go on preload with weight taken off the sled. I have not checked the rear spring sag yet. It may be a bit stiff, but not by much. This sled is stretched to 128" as well. I noticed that out of the 5 adjustment holes in the limiter strap, it is currently in the 4th tightest hole. I don't know if I should go to the 5th or not as it may increase steering effort too much. My wife drives this sled as well, and it's a toss up to either increase steering effort, or attempt to keep the skis planted in turns. The inside ski lift is worse with her I think due to again the rear spring sag isn't enough, and also she just doesn't slide her #*$&@ to the side a whole lot in the turns.
Looking for some insight. Thanks.
Try going back to the stock position which is the second hole on the limiter strap and then set the transfer rod to min.
You could also try a thicker sway bar to help keep the sled flatter in the turns.
Firecat_Freak
Already has the thicker sway bar. I'm trying to remember if I get ski lift only under power in the corners, or also off power in corners. I can see that the transfer rod to minimum would help under power only in turns. I do know that when I sit on the sled it still slants forward, it doesn't sit level so maybe my c.g. is too high. May need to check sag before I do anything else first.
rvtransport
Believe it or not skies will also help. Try a set of Yamaha tuner skies. Steering effort is light and put longer carbide to inside of ski. Then when u get ski lift the ski will give a little with shorter less aggressive outside carbide. They my push a little but I ran more front spring pressure and helped both ski lift and pushing. They track straight also. No comparison to stock skies IMO.
