BigJeffMN
I have one weekend of rippin up the snow and I noticed my limiter strap has slack when the sled is just sitting, a buddy tells me we can tighten that up to change two things. First thing is the slow speed turning will be easier and second is better performance in deep snow. Is this true?
THis site rocks!!!!!!!!!!!!!! Been a member for 3 months thanks everyone!
Malmlof
I have mine in the shortest position.
(with the control rod in the middle position)
Pros:
Makes the sled trench less in deep snow.
Minimizes inside skilift in corners.
Better steering on power.
Better control when hillclimbing.
Overall better handling for fast trail riding.
Cons:
Less comfort on rough trails when cruising.
Acceleration from standstill will suffer = less weight transfer.
Less skilift.
Mine started to make clunking noises when I shortened the strap, but I made the rebound slower on the shock and it disappeared.
This is my experience and I have tried all positions on the strap.
I have not noticed any change in slow speed steering with the different positions.
It is easy to adjust, so try it out and see what result you get.
/Richard Malmlöf Sweden
Pros:
Cons:
Less skilift.
Hammer 1
How do you adjust this lmiter strap? Do you jack the front of the sled to get some slack? Mine is tight.
YamahaMainer
You'll need to compress the rear end to give it some slack. When my father needed to change his I actually just stood on the rear grab-bar until he was finished.
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Put a chunk of wood or something under the front of the track and then have someone sit on the sled, this will compress the front and provide slack in the straps.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
BigJeffMN said:I have one weekend of rippin up the snow and I noticed my limiter strap has slack when the sled is just sitting, a buddy tells me we can tighten that up to change two things. First thing is the slow speed turning will be easier and second is better performance in deep snow. Is this true?
Good post, I was curious on the different settings as well.
Think I am going to try 1 hole tighter on mine as I believe mine are still set to the factory settings?
Any more pro's or cons or anything else one should do after tightening up the strap?
mr. shide
mine is set all the way loose. it does make a clunking sound when going really slow over large bumps or over berms at road crossings etc. thought about tightening it up one hole?
sk-rx1
Clunking sound is the transfer rod. It is normal. People here have tried some fixes but most just live with it. I believe most of the fixes don't last very long and the clunking returns.
Super Sled
- Feb 25, 2009
- Summit X
My limiter always has slack in it while the sled is just sitting there -- and I keep mine on the second from tightest setting. But when the sled is moving and the track is spinning it is tight.....
mr. shide
thanks for the info. i'll leave it alone!
Super Sled
- Feb 25, 2009
- Summit X
Malmlof said:I have mine in the shortest position.
Pros:
Cons:
Less skilift.
I have my limiter strap at second from tightest position and my transfer rod set for almost no transfer. I like it. I also second malmof's pro's and con's to a "T"......
