number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Well this fall i added a ulmer stage 3 kit ot my vector, windage plates, holtzman green carb springs, CR10ek plugs and a 21T top gear. I have been really anxous to line it up with some other sleds to see how much I gained. My neighbor races snocross and he was out riding his 06 factory mod 600 rev tonight. It was about 10 degress F and there was only about 3-4" of snow in the field. He has the real agressive track with 96 studs and i have a unstudded ripsaw.
I knew he would smoke me if we started from a dead stop because of his traction advantage so we rolled at about 10 and hit it. I was expecting to get clobbered but i didnt do too bad. He pulled me by about 3 lengths and it pretty much stayed that way til we hit about 70 then he let off. Did it again with same results. Overall i am really happy that a 150hp sled that wieghs about 150 lbs less then me could only pull me by 3 lengths! Cant wait to line up with a stock vector! This weekend i will likely have a chance to run a Jag. I will post the results on sunday!
MadMax
If you don't beat that jag.......... Don't bother to come home..........
MM.
MM.That jag is a 1000cc 4 stoke right??
HP??
HP??
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
1100cc 125 hp
Tfin
I'd be willing to bet if you had 144 studs up your center belt, it would of been a heck of a lot closer!
