2018 Sidewinder LTX-LE. I need to drop the skid to put BOP coolant hose protectors in. Can someone tell me the exact screws I need to remove. I’ve seen some posts but I’m still not sure what to do.
Froggy
- Apr 29, 2016
- Kipawa,Quebec
- 2020 Winder LTX SE 17600 km and counting
2016 Viper LTX LE 23986 km sold
2015 Viper LTX DX Wife's 22500 km sold
2010 Vector LTX GT 25000 km sold
2024 SRX Leftover 3700 km
ralphm, First I loosen my track and then I remove the idler wheel shown in the white circle and I carefully remove the spring guide for the torsion spring. Then I remove the bolts in the orange circle to drop out the skid as the front arm slides in so there is no need to unbolt anything for the front arm. This is from 2020 ltx se.
Turboflash
- Mar 18, 2019
- Southern MN
A little hint if you haven't already seen this but take the plastic spring holders out and slot the top just enough so you can "snap" the springs out of them so anytime you want. Then to remove skid you can just pop them out and bring the long end out past the idler wheel and down to unload skid. Saves you from having to remove the idler wheels each time. You may have to lift back of sled or put a jack under the track in the back. You can then collapse the rear shock to make it easier to get skid out.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Turbo flash, have you ever had issues with the spring trying to jump out of that slot?
MS
MS
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
When removing i leave the torsion springs on cause the whole things drops out pretty easy, but when re installing i leave them loose so its easier to move the scissor around to line up the hole.
When the skid is out check the front cross shaft to make sure it is not starting to bend. BOP also sells a kit to reinforce this area of the sled - the crosshaft and the side of the tunnel reinforcers.
MS
MS
Turboflash
- Mar 18, 2019
- Southern MN
Never. Been doing this for 25 years on all my sleds. Have never had a single time when spring came out. The spring has a ton of pressure pushing into the holder so it's not gonna come out.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Then they are getting cut the next time the skid is out. Thanks
Miss the stirrups from the nytro.
MS
Turboflash
- Mar 18, 2019
- Southern MN
Measure the spring diameter. Cut the slot a little narrower than spring diameter.Turbo flash, have you ever had issues with the spring trying to jump out of that slot?
MS
