wantler
- Jan 26, 2013
- 100 Mile House
- 2010 Nytro MCX 240
Hi,
I know this is not the electrical forum, but I tried there and had no luck!
my problem is that I don't get any power to my Lights, DC. these are the fuses # 3,4 and 5. I know that they get energized from the load relay after starting the sled.
the relay works fine, checked and changed it.
found out, that when I give ground (extra wire) to the blue/brown wire on the relay, the relay clicks and my lights come on.
could it be that there is a problem in the ECU?? that blue/brown wire goes direct into the ECU.
and if it is the ECU, before I have to buy a new one, can I switch ground directly to that wire (blue/green) to make it work like that??
thanks for any input on that.
