attack related
I got a used sled with no owners manual maybe someone can help. I need to know how to read codes and why the yellow caution light stays on.I had the sled serviced in march this year at the dealer then rode 300 miles then put them away for the season with charging the battery with a 2 amp charger every 2 months and putting stable in the tank. Now when i started it the yellow caution light is on , what does this mean ? I ran it for 15 min. then shut it off for5 min, the oil an water is ok, I then restarted it and ran it another 5 mins an the light is still on. I will try to get to the dealer soon. any help would be appreciated..thxs
radianguy
- Jan 1, 2007
The yellow light comes on when the fuel is low, did you check your fuel level?
There is a list of codes in the FAQ section.
http://www.ty4stroke.com/viewtopic.php?t=36172
Apex owner's manual
C:\Users\User\Documents\LIT-12628-02-53_apex_er_1331.pdf
copy & paste
copy & paste
attack related
can you recheck that copy an paste document it's not working
works for me--copy then paste into your browser then enter
does it work for any one?I'm not the sharpest knife in the drawer with this
Len Todd
The shortcut given will not work for you. It is a shortcut to the provider's hard drive file. Not sure what he is thinkin'. Besides, the document is proprietary. He should not be trying to pass it on to you.
For your problem, you may want to consider checking the fuel level, as indicated earlier. You need a couple gallons in there for the light to shut off.
Len Todd said:The shortcut given will not work for you. It is a shortcut to the provider's hard drive file. Not sure what he is thinkin'. Besides, the document is proprietary. He should not be trying to pass it on to you.
JUST TRYING TO HELP
apltx08
tcona-AGT said:Len Todd said:The shortcut given will not work for you. It is a shortcut to the provider's hard drive file. Not sure what he is thinkin'. Besides, the document is proprietary. He should not be trying to pass it on to you.
JUST TRYING TO HELP
No its not working...
LJ 452
You can go to this and download it.
http://www.yamaha-motor.com/sport/servi ... nuals.aspx
It's at the Yamaha Web site so it should be on the up and up.
I would check you fuel level and stated, then check the air box temp sensor as well as any other sensors that get disconnected durring the oil change process. You should see a code flashing.
Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
Have you looked at the Apex/Attak FAQ at the top of this forum? In that thread is a link to the service manual.
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
this is classic.tcona-AGT said:Apex owner's manual
copy & paste
Shootinstick
tcona-AGT:
FYI: Not to belittle you as I realize you are trying to help out a fellow TY member and you expressed your lack of computer literacy. Unfortunately, your link will not work for others as it is pointing to a file on your own personal hard drive, which others don't have access to.
blustar
- Mar 11, 2009
- Manitoba
- members.shaw.ca
- Yamaha Apex and RS Vector
Does anyone know where to get the file for the 2008 Apex Service Manual?
attack related
2007 attack
ok thanks for the help guys ....newbie here to the yamaha world ...bought them and will never look back..so happy with the long track an fuel injection ...amazing.....
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
attack related said:I got a used sled with no owners manual maybe someone can help. I need to know how to read codes and why the yellow caution light stays on.I had the sled serviced in march this year at the dealer then rode 300 miles then put them away for the season with charging the battery with a 2 amp charger every 2 months and putting stable in the tank. Now when i started it the yellow caution light is on , what does this mean ? I ran it for 15 min. then shut it off for5 min, the oil an water is ok, I then restarted it and ran it another 5 mins an the light is still on. I will try to get to the dealer soon. any help would be appreciated..thxs
Here's the service Manual: http://www.ty4stroke.com/viewtopic.php?t=58628
Would you mind adding your location to your user profile, it's a site requirement.
rxrider
TY Management
