looking for 6" replacement wheels
maim
Staff member
Moderator
sudbury on
Canada
2016 apex xtx
for a vk540II/III. trying to find some aftermarket 6" wheels for my uncle. they go in front of the rear axle and aparently there is nothing other than this model of yamaha that has this size wheel. looking for a source other than yam (wants big bucks and they still wear funny) for a 6-6-1/4" wheel.
thanks maim.
This link will take you to Royal Distributing's catalogue on pg180: http://www.royaldistributing.com/Shoppi ... 9/180.html
There is a 6 inch idler wheel (04-116-86) that comes with a 6205 bearing. I don't know if that works on your Uncle's sled though. If the stock idler bearing is a 6005, you can modify the mount to accept the wider 6205 bearing.
thanks. trying to find some without holes as the slush/snow packs in through the holes and stops the wheel from turning no matter how many times you clear it out.
