looking for 8 tooth extro's on drive axle
Why not do it yourself? Its a pretty easy process -once you have the drivers in hand and the axle out, its a half hour job to swap them.
its easier to have a whole spare ready to go when i want to change tracks back and forth. pressing drivers on and off every time i want to do a swap is a pita. i run different tracks for different conditions.
I talked with Allen Ulmer, who stated the shaft will work as long as you use the washer and updated bolt for the 08. The 08's broke the bottom gear bolt and the fix was a new bolt and washer. The shaft from 08 to 09 has a longer stub shaft on the 09. The chaincase/gears/cover/bearings are all the same from yr to yr.
