Pbadgley
- Feb 16, 2011
- Inuvik NT
- 2004 Yamaha RX Warrior
Okay I put a ton of money into upgrading my front suspension this past summer and I must say I love the way it handles now but there is one more thing I want to do. I want to install a 13mm sway bar. The sled still dips to the outside when cornering hard in most snow conditions more so in deep powder.
Has anybody posted a good how-to with all the parts needed including part numbers? My search skills have failed to yield my good results.
my current sled specs are found bellow.
stomper
Just did mine last year. It is simple. All you need is:
13mm stabilizer bar
2 13mm stabilizer bushings
2 13mm stabilizer links
best place to get them is here
http://pioneerperformance.net/store/page2.html
Real easy to do, took me about 5 minutes.
1. Remove the bolts that holds the link to the a arms
2. Remove the pinch bolts holding the link to the stabilizer bar
3. Pull the stabilizer bar out
4. Remove the bushings. They just pull out from the outside
5. Reinstall all the new stuff
6. Have a drink of your beer!!
The new stabilizer bar should have a mark on each end and you will have to line up the links so they are in the same orientation.
Hope this helps
13mm stabilizer bar
Hope this helps
Pbadgley
- Feb 16, 2011
- Inuvik NT
Wow that is pretty simple. Thanks for the input.
RxThunder
It was a simple job, and you will be very happy that you did it. I just ordered one for my Apex, my RX1 was night and day after I did the 13mm seay bar.
As you have an 04, you should not need the sway bar links. They where upgraded in 04 to the ones you need. I just put it in on my old 05 and it all bolted up.
- 6K
