Hi Guys. Going through my machine. I realized that the clutch setup in there now is not stock as I thought. I haven't removed either of the clutches as of yet, however from what I can see the primary spring is solid black; secondary is black with a pink stripe. No idea on weights / helix as of yet.
Regardless, what I'm looking for is the mildest clutch setup I can run without having the engine bog. I'll be mainly doing trail riding between 20-40mph, with the occasional railbed stretch of maybe 80mph tops. If I could find something with about a 2000-2500 rpm engagement that would be great. I've got the Yammy spring chart, however engagement rpm's aren't listed.
Any setup recommendations would be greatly appreciated. Thanks in advance
Just buy a low engagement spring for primary you will engage @ about 2800rpm and ride it first you may like how it work's unless you just like spending money, and won't know which is better. SchmidtBrosMotorsports sells the proper spring for low engagement.
