LANEO
Guest
Looking for best kit or set up to get to use to dial in clutch. sled has bender stage II kit and I am looking to dial in at 18 lbs of boost. What is the best kit to use to make changes or do I have to weld & grind. Any suggestions? Thx
snowy1
it depends what altitude and what kind of riding you are going to use it for I ride the mountains 9000 to 11,000 ft. 8bu-00 welded up work really well for me.
lancef53
PIC
Any chance someone has a pic of one of these welded weights?
What does the weight weigh?
snowy1
it depends on what elevation you are running at and how much boost, I am running about 62 grams at 18lbs at 10,000 ft. it will depend on which profile you use as will. no pics.
lancef53
What size rollers, springs, helix? Thanks
snowy1
14.5 rollers, and light spring,I ran a y-p-y 30-113 last year will be running b-p-b, 30-97 this year,again on the helix it depends on what elevation and how much boost you are running, I have seen anything from stock 45% th 51 % helix this is in the mountians, flat landers will propable what something different.
