Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Where on the Sidewinder are you guys tapping in for GPS. I have my heated shield plugged into here. What's this to the right. Doesn't have power.
Well.......let me know.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Rocks power supply.
Doc Harley
- Oct 17, 2016
- Here & there
Thank you!Rocks power supply.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
That’s just a cap find a splitter and spice both in where your heated shield is
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
cat makes an adapter to allow 2 or 3 things to be plugged in there. 1639-624 is part number for the 3 plug unit
Doc Harley
- Oct 17, 2016
- Here & there
I'll give my dealer a jingle. Thanks for the part #cat makes an adapter to allow 2 or 3 things to be plugged in there. 1639-624 is part number for the 3 plug unit
burlyviper
- Apr 30, 2012
- Ottawa Lake MI
- 2018 Sidewinder LTX LE, blue
2011 Apex 128, Ulmer Airbox and clutch kit, PCV, HID
1980 Exciter 300
Most guys have a splitter that connects where you have your heated shield. You can Y off this plug and have 2 or 3 connections.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
saskattakman
cat harness works great plug and play and under $10
can also get SAE splitters to tap in there that have in line fuses
Yamatario
- Jan 8, 2009
- SW Ontario
- 2018 LTX SideWinder
2015 Viper LTX DX
2009 Nytro XTX
What are the two spade terminals hanging by the battery?
PowderFalcon
Pinnin' it!
I ran the power for my GPS and heated visor direct to my battery with fuses on each
Doc Harley
- Oct 17, 2016
- Here & there
Took GPS harness, spliced in a tender style connection. For a simple plug & play. Then the y splitter for the finishing move. It is what it is. Wrap up the spaghetti and go to town.
Doc Harley
- Oct 17, 2016
- Here & there
Do you have? Does it work with tender style pigtail?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I have one on my Nytro but not on my Sidewinder yet.
He makes them so they are plug and play
for your sled model.
It has two USB ports and two RCA ports on the hub.
I bet if you contact Rock, He can put and source of power plug you want on it.
