Looking for softer ride on 07 rtx
blurred vision
Cornwall Ont.
I was woundering if anyone has any ideas on how to make a 07 rtx ride smooth before I Buy new ohlins for the front and maybe a new skid. My wife rides the rtx and weighs 130 so she finds it very rough. Any info would be of great help. Thanks
I wouldnt touch the front, check psi in fox floats with front elevated, drop them to 45-50psi and it will be great. The floats arent harsh at all but are a little stiff from the factory. Drop psi till you a-arms are near parallel with the ground and it will handle much better. If you want real soft for the back.......the vector uses the same skid, maybe swap out the springs and shocks with a vector. Should be plenty plush for a 130lb rider.
I have an 06 RTX with the monoshock suspension that I feel rides too soft and would be willing to trade you rear suspensions if you're interested. I'm just outside Buffalo, New York.
i do know my father's GT rides alot better then my '07 RTX. Alot more comfortable. i am 170 lbs and bottom the rear of the RTX on the highest settings... need to do some work in the off season
