Yamaha RX-1 Power Lineman
- May 29, 2014
- 2005 Yamaha RX-1
im looking to build a carb synchronizer for my RX-1. Ive seen multiple pages on google each a little different from the next on how to make such a tool.
Sooooo...... Im asking you Totally Yamaha Members to point me in the right direction and help me find the right specs to build such a tool for my RX-1
Thank You So Much.
ps......I did you the search function for this and Im not satisfied with what I have found so this explains the thread
Thank You So Much.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I posted this for the three cylinder engines but it works the same for the RX1 engines.
http://www.ty4stroke.com/threads/carb-sync-tool.108472/
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
I bought one from Royal distributing, A guy could build one but it was so much easier to buy one.
- May 29, 2014
- 2005 Yamaha RX-1
built one today.......pretty easy to build and i made it for 14 bucks. Used Chainsaw Bar oil( its nice and bright red. Looking forward to seeing how it works
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Used the same tool to sync the carbs on an old Yamaha Radian motorcycle over the weekend. It works well.
xj4me
Grizztracks tool and write up is the way to go. Had my rx purring like a kitten last year!
superfan75
I'm going to make one this summer when I start to go through my sled. It looks fairly simple to make and use. It sounds like it can make a big difference it the carbs are out of sync. I have a question for those who had these 4 strokes for a while. How often should the carbs be synced? Once a year when the carbs are cleaned ??
xj4me
I did after cleaning the carbs, Some recommend syncing after a full tank of fresh gas
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I sync the carbs every year after running a couple of tanks of gas. If the carbs are removed and cleaned you should always resync them.
superfan75
Okay, Thanx guys !!
