vodoo child
- Oct 29, 2005
- Palmerton Pa.
- 2018 Sidewinder LTX/LE 50th
I can rotate the gauge pod on my Sidewinder about a 1/2 of an inch. Any one else have this issue, and a fix? Thanks
Pull it off and see if the molded clips are broke on the gauge.
vodoo child
- Oct 29, 2005
- Palmerton Pa.
Pull it straight off, or is it twist locked on?Pull it off and see if the molded clips are broke on the gauge.
I just pull them straight off and then unplug the harness.
vodoo child
- Oct 29, 2005
- Palmerton Pa.
Ok, thanks!I just pull them straight off and then unplug the harness.
Joseph Levandoski
- Oct 19, 2016
- Ellington, CT
- 2019 Yamaha Sidewinder X-TX LE 141
My Viper gauge started to rattle after getting snow and ice behind it - a little bit of black silicone solved that issue real quick.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
My buddy bought a used 17 RTX LE last season with about 9 or 10K on it and his pod was loose just like what was described. He fixed it with some double sided tape. Mine 17 LTX LE was tight at the beginning of last season but when I put it away at the end of season, it was also pretty loose. So Probably just another CAT DNA thing!
