Loose throttle block
joyrider
WI
I noticed my throttle block and left switch housing move somewhat easy while I installed some handguard. The bolts are tight as they should be without stripping and they still move relatively easy. Anyone else notice this. Any easy fix ideas out there.
We have seen this in the past with vipers and cats. Although you should not have to do. We just unscrew the throttle block (right side) or the switch block (left side) and put a quick wrap of electrical tape on the bars then reinstall. Should tighten up nicely.
