Lopsided Rx-1M
yamahamaniac
Jackson's Arm, Newfoundland, Canada
Made a post a while ago about this problem but didn't get any feedback. My '03 Rx-1M has a very bad tilt to the throttle side which seems to be in the front suspension. When you are standing on the sled you can feel that it is down on one side and that same side seems really easy to bottom out. I've tried 4 different shocks (with 4 different springs) and it didn't change anything. Any idea what could be causing this?? And no the front bulkhead isn't broke.
bend spindle or twisted A-arm?? did you check rear suspension? make sure nothing is binding up back there forceing the nose down,,,
The undercarriage has been out a few times since this has been happening so i can't see it being the rear end. I always have a really smooth ride when it comes to the rear end too, however when I'm going across a slope and the throttle side is pointing downhill I can just barely keep the sled upright in hard pack conditions.
