Low snow wheel kit
Il cin769
Age
55
Vector
guys what are your thoughts on low snow wheels? Daughter doesn't quite understand keeping snow in the track to cool hyfax
Do these help? Where do I get the kit?
Just call Travis and he'll send you used wheel mounts and new or used wheels.
I changed all my stock 130mm wheels for 135mm polaris wheels (red ones) plus added frt wheels and 4th wheel on sides.
JMO, waste of $$$-
Think about how small they are & fast rotation, they got loose/ bearings went and froze up.
I went with Excell X wheels across the front as they're bigger & no more problem.
Threw away $70 first time....
Also may wants to think about the type of slides. The DuPont one are suppose to be long lasting and I ran the white ones on my 136 with no extra wheels and low snow and them didn't seem to wear much.
JMO, waste of $$$-
JMO, the reason for bigger wheels were for less hyfax wear.
And if you have a wheel bearing go bed it's because YOU didn't service it.
It's for sure not a waste of money!!!!!!!!
The small wheels are known to fail even with religious maintenance. Dupont slides or Excell. pick your poison. They both work.
