09nytrorider
I was working on replacing my lower a-arm ball joints and have questions around once the new ones are in how stiff are they supposed to be. One I pressed in (and it did press in evenly) i can't move will my fingers but if i put a bolt in it moves but stiffly. I had trouble with this one pressing in initially but put ball joint in freezer to see if that would help. Might of helped a bit since i got it in this morning but again it seems rather tight. The other side a-arm i can move ball joint with my fingers. Any thoughts would be greatly appreciated. I have an 09 nytro and got OEM ball joint. Thanks
Keith1962
- Mar 26, 2015
- Camillus, NY
- 2009 Nytro XTX,OFT Relocator, Excell exhaust, Curve Skis, Excell wheels, Dupont Slides. Star Suspension. Hygear Billet rear shock and spring spacer. Air Box Mod. Clutch mods, Polished tunnel. Custom GPS mount. BOP Skid Plate. RSI handwarmers.
How still was it before pressing it in?
09nytrorider
Wasn't stiff before pressing in. I could move with fingers.
Keith1962
- Mar 26, 2015
- Camillus, NY
It really should not have changed. I assume you pressed on the outer race and not on the ball?
