opt8low
- Feb 14, 2007
- West-Central MN
- www.opt8low.com
I am thinking on getting a XTX but am having trouble deciding. I ride a REV right now and I have all the paint rubed off my lower A-arms. The reason I say this is that I am worried that I will have trouble with the Swaybar attachment points on the Nytros lower A-arms. I ride mostly off trail in N.D, MN and the U.P. of MI. I think I would be hitting those mounts and swaybar and ripping them right off, or at least bending the #*$&@ out of the sled.
So has anyone had issues with hitting stuff with the swaybar and/or it mounts to the lower A-arms???
I would love to get this sled but I don't want to have to fix #*$&@ all the time. I can do that with what I got.... Oh I want to keep the swaybar for the times I ride on the trails...
thanks in advance,
Dana
thanks in advance,
Dana
Kråkan
you could put A-arm protectors on it... Or move the swaybar mount like on the Iron dog sleds to between the A-arms...
gormleyflyer2002
yes you will......search for some of 08nitroRTX posts......or look at the pics of the iron dog sleds. He moved his sway bar location, a little welding but looked like a tidy job......Jeff built a pretty wild sled.
unpride
The 08 Yammi A-arm protectors dont work on the RTX. Hopefully they make new ones for next season
BLUEBALLER
- Jan 29, 2005
unpride said:The 08 Yammi A-arm protectors dont work on the RTX. Hopefully they make new ones for next season
what didn't you like? saved my a-arms more than enough times.
unpride
The last rubber mount wouldnt go through the A-arm by the spindle. They work fine on the standard. Brought them to the dealer and they verified it and called YamahaBLUEBALLER said:unpride said:The 08 Yammi A-arm protectors dont work on the RTX. Hopefully they make new ones for next season
BLUEBALLER
- Jan 29, 2005
unpride said:The last rubber mount wouldnt go through the A-arm by the spindle. They work fine on the standard. Brought them to the dealer and they verified it and called YamahaBLUEBALLER said:unpride said:The 08 Yammi A-arm protectors dont work on the RTX. Hopefully they make new ones for next season
You had to drill a new hole for the mounting bracket. I posted pics on this when I first got mine. worked great all season long. do a search and you'll see how they mounted. Personally, I'd never run without skidplate/a-arm protectors.
