SnoBird888
- Sep 4, 2013
- Neenah, WI
- 09 Nytro xtx
Anyone have experience lowering the clutch engagement for the Nytro? I have the Ulmer stg 1 clutch kit for my 2009 xtx. It works great but i want lower engagement so its easier moving around and general low speed smoothness. I currently have the orange pink orange spring which is 30kg preload This is the lowest preload Yamaha sells for the long type of spring. Its 33mm force is 137kg and is 3.2 kg/mm. I was considering trying a spring that has a lower force rate so it pinches that belt and moves ever so slightly with less force. however the clutch weights will need to be adjusted as well.
Im used to Polaris clutching with the starting and final rates which controls engagement and final rates/rpm and assumed Yamaha springs work the same. However with 30kg being the lowest offered im stuck on what springs are sold by Schmidt bros for the comfort kit or BOP for lower engagement.
