Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
I'm looking for feedback on lubricating these bearings
Do you drill a small hole in the side of them and then use that syringe needle that attaches to the grease gun?
YamahaRx-Warrior
Also want to know
Justin
Justin
DaveRX1
DO NOT DRILL ANY HOLES!!! It is stupid simple, Grasp the grease needle in one hand, carefully insert the needle through the rubber seal between the seal and the inner race. When you get it at the correct angle it will go into the bearing 1/4" or so. Now push the grease gun onto the needle zerk, slowly pump 1-2 pumps if you have done this correctly you will see grease push out of the seal slightly at various point around the bearing. Pull out needle and your done. This should not take more than 30sec. I do this every 1000-1500 miles.
DaveRX1 what kind of grease are you using on the bearings the standard lithium grease used on the spindles etc. or wheel bearing grease?
DaveRX1
For years I have been using "boat trailer" water resistant wheel bearing grease on everything I own from ballbearings to balljoints. No failures.
Bob Miller
- Apr 19, 2003
- New Milford CT
Thanks Dave
That's good to know 8)
slims427
- Dec 2, 2003
Grease
Get yourself some Amsoil water resistent grease. The best for all snowmobile use. Slim
Bob Miller
- Apr 19, 2003
- New Milford CT
How about Synthetic Grease?
RX1 Yooper
You mean there is a grease that is water soluble?? I have yet to see a grease that is affected by water. Is that what the manufacturers recommend? I'll look in my owners manual.
impalapower
It would be or should be a wheelbearing compatable grease. It would be fine to use synthetic grease. Yooper is right, what grease is water soluble.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
amsoil is synthetic.
stinx
where could i get a grease needle for my grease gun? would sears have it?
whits-end
One of my biggest peaves is with NTN bearings, with the blue seals.
These are supposed to be premium sled bearings, but the grease cakes up and won't last at all. If I'm forced to use them, I pop the seals off, wash them out, and repack with a wheel bearing grease.
Obviously much easier to just buy another brand, but you almost have to go to a bearing supply shop to find another brand, at least in Canada.
Great marketing job by NTN, I guess, but I wish their bearings came somewhere close to their hype.
If you use their aftermarket drive axle bearing, it's an annual replacement, guaranteed.
Always wondered why Yamaha couldn't design them like Polaris, easy to lube.
Bob Miller
- Apr 19, 2003
- New Milford CT
stinx said:where could i get a grease needle for my grease gun? would sears have it?
Hey stinx,
I got mine at NAPA
RX1 Yooper
Couldn't you install a grease fitting on the driveshaft, and with some ingenuity, on the jackshaft? You'd have to remove the seal, of course.
