lug hieght
grooter
anyone know that max lug hieght that can be used on an 07 apex rtx 121" ex. 1.5, or 1.75
Without being notched you can go 1.5 but if you notch track or it is notched you can go up to 2", Ive done it.
Drives and track have to be perfectly positioned to get them in and out, this is with oem 9 tooths drivers,im sure a 8 tooth would fit fine. And if your going that deep of a track youd be better off wth 8 tooth drivers as it will get you closer to the gearing youll need.
Im looking too put an 1.5" on mine did the tunnel protectors need too be removed too fit a 1.5" ?
