mikeb
Can I M-10 be removed without damage. I'm thinking of buying a used on but looking at the instructions it looks like some of the mounts have to be drilled to fit. I dont want to have to buy a new mounting kit.
JD
- Apr 14, 2003
- Manitoba, Canada
- 2016 Venture TF-LE
Removing is not a problem....Just make sure that you get the mounting kit...The kit consists of the rear brackets that will bolt up to your tunnel...and I believe the spacers for the front are to match the Rx tunnel width.....Get all the bolts too.....I would actually only make the deal...after it's been pulled....
The drilling that has to be done, will be on your sled…..That’s when you position those rear brackets…
Check out this TY link….it was a big help to me….http://www.totallyamaha.com/ExpertX_M10 ... ll%20R.htm
JD
JD
