M-20 Airwave from Team Fast
I can attest to the weight sensitivity of the M-10. I've got the 136 version in my Vector and set the FRA up full soft for my wife. It bottomed a couple times for her. I rode it and it bottomed everywhere. I weigh about 50lbs more. I then rode the sled with my 70 lb daughter and it was unrideable in bumpy conditions. It would bottom and didn't want to spring back up right away.
This weekend I got so sick of the lack of transfer and the bottoming, even with the FRA set further ahead, I did the following. I removed the coupler blocks and trimmed them down 1/4". I put the center shock limiter strap at 4/4 and tightened the center shock preload. I set the FRA in the middle of the adjustment and finally, the sled will pull the skis when climbing in spring snow. It is also more resistant to bottoming, but I lost that cushy ride in the stutters. It still bottoms hard in g-outs and can't handle them. I also lost top speed because the approach angle is steeper with the front limiter being let out all the way.
The M-20 is supposed to work a lot better than the M-10. For cruising, a guy will probably be happy with it. For performance riding I think the M-10 sucks. I have a used Ski-doo 136 SC-4 that I'm going to install in my Vector. After two seasons of experience with my M-10, I'm not impressed with it's all around capabilities or performance. It just doesn't have a big enough window of performance to work well in all conditions without being adjusted. That to me is not an improvement. A standard, rising rate, scissors type skid works well everywhere and just isn't as temperamental.
Please note that I am not trying to put shite on the FAST skids, but I doubt this is the route you want to go with a stand-up riding style snocross replica. If I am not completely mistaken, the main design goal behind the FAST skids is to offer maximum coupling in all kind of situations, "parallellogramming" the skid and reducing the effective spring rate the further down the stroke you get, in order to offer maximum comfort in bumpy conditions...? I can not see why anyone would want this in a stand-up riding style snocross replica...? It is obvious that some of the design goals behind the snocross replica - like the possibility to induce wheelies with the throttle, adjust wheelies by body position or preload the skid for the next jump - will be gone if this skid is installed...
