Harvey Lunnen
Has anyone had a problem with the ignition breaking-I've broken two before finaling getting one that works!! For no apparent reason the second one broke even on the first attempt to start.
06RSRAGE
"Has anyone had a problem with the ignition breaking" The Key?? The switch??? The starter?? Please explain what you mean...
Harvey Lunnen
It is the actual part where you insert the key it is call the main switch assembly on the parts list!
air19
My ignition switch turns the engine on, but it doesn't turn it off. I can turn the key back and pull it out and the engine just keeps on purring. Have to use the kill button.
I have a 2008 VK Pro and the dealer is replacing my ignition switch.
- 6K
