jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Does anyone know if this was discontinued and when? So on my 2022 I have two lines coming into stock airbox. One is from the ROV 5/8". The other is crankcase vent line 1/4" . Nothing else.. On the back side of the airbox it has a nipple but nothing attached to it.. I thought there was a line attached on my 17 sled? Did the 2021 have 3 lines going to airbox?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Check this out.
ty4stroke.com
Plugging the wastegate solenoid vent?
Has anyone had there wastegate solenoid vent plugged by dealer? I have 2 winders here both with plugged vent lines both had codes and this was yamaha recommendation (both stock at the time) One is stock and runs fine The second one is tuned and is getting only 13lbs on 270 with both hurricane...
ty4stroke.com
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
ALL the lines labeled on the 22 I have. When I put the GAP 3 bar in I noticed no hoses hanging out not used
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Looks like I didn't read far enough. Thanks Tim. this might have cleared things upCheck this out.
Has anyone had there wastegate solenoid vent plugged by dealer? I have 2 winders here both with plugged vent lines both had codes and this was yamaha recommendation (both stock at the time) One is stock and runs fine The second one is tuned and is getting only 13lbs on 270 with both hurricane...ty4stroke.com
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
They could have at least plugged the back side of airbox! I suppose it could have fallen off.. Not my guess though
HABS 1
- Oct 22, 2015
- corunna,ontario
that had a tight plug on mine , capped off , on back of airbox,it is snugg , probably forgotten lol, where is that valve located? im curious now and want to see if a line is on it venting downwardThey could have at least plugged the back side of airbox! I suppose it could have fallen off.. Not my guess though
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I'm going to look VERY closely later today!that had a tight plug on mine , capped off , on back of airbox,it is snugg , probably forgotten lol, where is that valve located? im curious now and want to see if a line is on it venting downward
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
The valve/nipple that no longer has a hose on it is located under the fuse bundle. If i understand it correctly the hose was eliminated and just a bare nipple is what is recommended/or cutting hose in half and leaving hang to lower body?where is that valve located
HABS 1
- Oct 22, 2015
- corunna,ontario
ok its under fuse bundle, i will check, im just looking at that 21 tech update picture and yes looks like they may have just put a piece of line on or nothing ar all, thinkin a pice line pointing downward wouldnt hurt if there was nothing on it
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Yes. Mike has been doing this disconnect for awhile. I will check and see what they did on the 2022.. I never had a freeze up in 13K miles on my 17 but its sounds like the line was freezing up when it was connected to the airbox. I was going to try a WAI and they all have 2 nipples for 1/4 hose lines.. The guys making the WAI warm air intake(mikes words) are not aware of the changes either.. They all have two leads on them
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
2022 no hose.
Mystery solved.
HABS 1
- Oct 22, 2015
- corunna,ontario
lol yup , are u putting one on or leave it?2022 no hose. View attachment 163676View attachment 163677Mystery solved.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Leaving it. Unless someone can tell me why I need a length of hose on it?lol yup , are u putting one on or leave it?
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
My line froze last year and I couldn’t figure out why I was down on boost. Someone on here told me about it and shared the technical update that removed the line completely on 2021’s. So after thawing the line out, I then removed the hose to the air box and bought the plug to cover the nipple. In looking at the technical update manual, the hose was completely removed.
- 11K
