bagadonitz
Yamaha Part # SMA-8FA95-00-00
Installed where I was seeing the most wear. Install simple enough (don't like that the brackets on the top couldn't just line up with existing rail holes but instead required new ones but I digress.
What I'm concerned with, is that these new wheels seem very low relative to the existing wheels. I realize that this is the point but it seems a bit much.
First, with a straight edge between the front wheel and the new wheel, note the space between the straight edge and the back wheel:
Second, with the same straight edge bent around the new wheel and placed on the existing wheels, look how low this new wheel will be:
This just doesn't look right to me. Seems too low. Will this cause problems with the track? With that much space between the track and the hyfax, would it be possible with any force perpendicular to the travel direction for track clips to get derailed so to speak?
Another question for you all. I have a set of new hyfax in the corner and I'm debating installing them before putting this back in. I know however that this set, at least if it is like the last I had in, are good for another 1000 km. Right around that wheel is the worst, they are still brand new around the rail bends. Would you replace these?
