Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
TD Max17pm
Stock primary spring
Qay-70's @ 71.3
9000rpm
Dalton BLK ORG V2 @ 6/2
XS825
Boost 16.8
Detonation light came on immediately so I added boostane 1oz to 5gal.
Light off.
Pulls strong then seems to hit a brick wall @ 117mph.
Conditions are not perfect, rough. Temps warm at 32°F
Stock Sled pulls speedo 115mph all day everyday.
Is there something I can look closer at while I'm here?
Qay-70's @ 71.3
9000rpm
XS825
Boost 16.8
Light off.
Pstn head
condition of track, tension of track, or size of lugs possible ?
Boost, RPM, looks good...should be performing well.
Conditions have a huge effect on top speed.
Helix?
Gearing?
Helix?
Gearing?
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
If you haven't changed gearing you are probably just getting to top speed faster.
rev them up
- Apr 3, 2006
- Prince Edward Island, Canada
- 2011 Nytro XTX, Hurricane Exhaust, K&N, Pcv, Autotune, Pod300, Star Suspension,
2018 Sidewinder, TD Max Spool 17, CAI, TD 3 Inch Stock Muffler Mod, 3Bar, BOV
I'm thinking get rid of the stock primary spring
I'm running ms17
dalton black/blue primary,
dalton quay70(76gram),
v2 b/o 6/2,
tock 35 helix
high torque rollers
xs825 belt,
td stock mod 3inch
CAI
.running 18/18.2 lbs boost, 9000rpm, stock gearing, storm1.5 track and studded
I'm running ms17
v2 b/o 6/2,
tock 35 helix
high torque rollers
xs825 belt,
td stock mod 3inch
CAI
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Boost leak test first
Doc Harley
- Oct 17, 2016
- Here & there
Track is good, 1/4" sag, 1.25" lugcondition of track, tension of track, or size of lugs possible ?
Not perfect but very doable. I've ran on this type of surface many timesBoost, RPM, looks good...should be performing well.
Helix?
Gearing?
35° helix
21/41
Speedo numbers are going fast. Then just stops. 117mph is too low to top out 21/41???If you haven't changed gearing you are probably just getting to top speed faster.
My clutch weight to achieve rpm seems low. I was expecting to be @ 74g+I'm thinking get rid of the stock primary spring
I'm running ms17
v2 b/o 6/2,
tock 35 helix
high torque rollers
xs825 belt,
td stock mod 3inch
CAI
I have a Dalton BLK BRZ I could try & a Yamaha Blu Wht Blu
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Are you still running the stock BOV?
Doc Harley
- Oct 17, 2016
- Here & there
I'm afraid that was left behind.Boost leak test first
Also my IAC temps were pegged.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
21/41 should get you 124ish on the speedo.
Doc Harley
- Oct 17, 2016
- Here & there
No turbosmart, I'm not in a position to test for boost leaks, unfortunately.Are you still running the stock BOV?
stgdz
- Mar 27, 2021
- Buffalo MN
Did you trim the intake barrel clamps?
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
You are limited by the BOV. At 16.8, it should still run out of gear.
I’m surprised the stock BOV holds that high.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
You are topping out at 24/50 speeds.
Doc Harley
- Oct 17, 2016
- Here & there
Unfortunately, that's not going to happen. Made the move to a flatter lake....113mph . Also it was an afterthought as it's getting dark.
Tomorrow's another day. Just kinda thought it might be clutching. Uneducated guess.
