Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I'm sorry. Yes, turbosmartYou are limited by the BOV. At 16.8, it should still run out of gear.
I’m surprised the stock BOV holds that high.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
YepI'm afraid that was left behind.
Also my IAC temps were pegged.
Doc Harley
- Oct 17, 2016
- Here & there
Yes...Did you trim the intake barrel clamps?
Turboflash
- Mar 18, 2019
- Southern MN
Boost leaks.
Very high IAC.
Very high IAC.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Maybe try a different wrap on the secondary?
I don’t recall what wrap I had it at, but I lost 5-6 mph on top with the B/O compared to my stock secondary spring at 3-3.
rev them up
- Apr 3, 2006
- Prince Edward Island, Canada
- 2011 Nytro XTX, Hurricane Exhaust, K&N, Pcv, Autotune, Pod300, Star Suspension,
2018 Sidewinder, TD Max Spool 17, CAI, TD 3 Inch Stock Muffler Mod, 3Bar, BOV
I would try the Black/Bronze..close enough to the black/blue and adjust weight from there.. If running the stock bov..some use to turn it backwards to try..believe there is info on here about it. Should be close to 76grams and 18lbs boost...i take it your running a performance muffler? I ran 121mph with draggy in 1/4 on snow...nothing to brag about just giving you an idea of what you should be close to.Track is good, 1/4" sag, 1.25" lug
Not perfect but very doable. I've ran on this type of surface many times
35° helix
21/41
Speedo numbers are going fast. Then just stops. 117mph is too low to top out 21/41???
My clutch weight to achieve rpm seems low. I was expecting to be @ 74g+
I have a Dalton BLK BRZ I could try & a Yamaha wht/Blu/wht
Mototown
- Sep 11, 2018
- Apex 40 th
Try running a newer helix off 20 or newer sidewinder and stock spring setting. I think Yamaha had a discounted price on helix kit but not 100% sure
Doc Harley
- Oct 17, 2016
- Here & there
Secondary is warmer than primary & belt. Wish I had my stock spring with. Just to see.Maybe try a different wrap on the secondary?
Yes, I'll try black bronze & more weight.I would try the Black/Bronze..close enough to the black/blue and adjust weight from there.. If running the stock bov..some use to turn it backwards to try..believe there is info on here about it. Should be close to 76grams and 18lbs boost...i take it your running a performance muffler? I ran 121mph with draggy in 1/4 on snow...nothing to brag about just giving you an idea of what you should be close to.
It sounds like the 35° helix is like the "go to" helix. I'm not sure it would kill my top end???Try running a newer helix off 20 or newer sidewinder and stock spring setting. I think Yamaha had a discounted price on helix kit but not 100% sure
rev them up
- Apr 3, 2006
In my mind stay with the proven set up i had mentioned then go from there. Should get you close.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Likely a boost leak. Are these gps or speedo speeds? My sleds speedo seems to run 5% slower than other turbo sleds I ride with. Hurricane tunes. 117ish is where you run out of gearing before the clutches go into over drive
Doc Harley
- Oct 17, 2016
- Here & there
Blu Wht Blu is the yam springIn my mind stay with the proven set up i had mentioned then go from there. Should get you close.
BLK BRZ is Dalton.
I have the wrong sequence on Yamaha spring. Sorry
Speedo numbers. I just use them for reference.Likely a boost leak. Are these gps or speedo speeds? My sleds speedo seems to run 5% slower than other turbo sleds I ride with. Hurricane tunes. 117ish is where you run out of gearing before the clutches go into over drive
I tried to use my phone GPS app, to compare. But nearly zero signal.
I'm barely getting WiFi. I have to sit in one spot in the cabin. Lol.
Doc Harley
- Oct 17, 2016
- Here & there
I'll verify boost today. Then go from there.
I can play with springs, but doesn't make a lot of sense if I can't reach 18psi of boost.
Temps are going to be in the high 20's so IAC temps will be high as well.
I'll go to my 250hp tune and see if that can kinda cure both. If that makes any sense.
Could very well improve things.
21/41 gears with 9 tooth 2.86 drivers, 9000 rpm, no overdrive works out to just over 112 mph.
5% overdrive would give you approx 118 mph
22/41 gears would give you 118 mph at 1:1 and 124 mph with 5% overdrive
Also maybe the tune you are running works better at a lower rpm...the hp could be falling off above 9000 rpm?
Maybe you need a bit lower RPM with higher gearing?
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
time for draggy. Your phone btw should not require a cellular signal or wifi to read GPS unless it is fairly old. Some GPS apps want to download maps/locations/etc and refuse to work unless you have some internet connectivity. There are GPS apps that just give you coordinates and derived readings like speed but they will not be nearly as accurate as draggy which uses mems sensors to overcome GPS limitations.Blu Wht Blu is the yam spring
BLK BRZ is Dalton.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
handheld GPS etrex you won’t have a problem
