MBRP CAN ROCKS!
I found that the can is only a slight bit louder when idling, but when at mid-to-full throttle, it is a lower louder grumble. I hit 90mph across a couple lakes, but haven't heard it hit the limiter yet, so will keep listening for that to occur. I also noted that the spring was a complete pain to put onto this can (the gap between the spring mount on the motor and on this can was a bit more than the original 'suitcase'). Overall fit and finish is excellent and as so many others have noted, you can easily get to the chain adjuster bolt.
