RXONE
Anyone else out there running the MBRP canister and the Heavy Hitters on there 03 RX-1 shorty? I'm wondering now if my performance is suffering because I need to jet up with the MBRP. Or do I just need to fine tune my Heavy Hitters? We don't have very much snow here in Northern N.Y.. Somewhere between 2-3 " but it has been very cold here all week. Do you suppose if I tested on these conditions that it would be the same as say hardpacked trails? The ground is frozen solid mind you.
(BBY) Matt I tried calling you today at the shop but you were busy.I'd really like to talk to you on the phone and maybe get a close set up for my HH's and some advice on perhaps jetting. I'd like to test on Sat.
Thanks C.J. aka RXONE
LazyBastard
Watch your plugs. If they look like crap, concentrate on jetting first. Once you have the jetting figured out, tune the weights.
RXONE
Thanks!
Thanks L.B.! I'll try it out on Sat. What do ya think about the conditions here in Northern N.Y.? Good testing?
LazyBastard
Hmm.. hard to say without actually seeing it. I like to test on cold trails that were groomed YESTERDAY. That way there isn't too much hookup - real-world conditions. Tune it on what you'll mostly be riding.
RXONE
Thanks!
Thanks again LB! Will do!
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Does that can have a crossover in the pipe? I remember reading about the RX-1 development and the engineers having issues with the exaust not getting the torque they wanted. They finally achieved good numbers by inserting a crossover. I know some of the aftermarket one's don't have it to save money. The issues you are having could be do to lower torque numbers.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
MBRP exhaust & HH
RXONE,
What kind of performance problems are you having with your sled,
RPM's, carb bog, clutch problems ?? I am interested because I also am using HH on my sled and if my order from MCB ever comes in, I will also have the MBRP exhaust. We've received lots of snow recently so I will be testing once I get my exhaust. :?:
Mighty, according to MBRP there is a crossover hole in the pipes and this occurs where the two pipes meet and are welded together. I asked for some info concerning hp & torque and all I got were hp values per their dyno results and they look pretty good in comparrison to stock !! :!:
Once I get the exhaust I will be sure to check on the crossover issue,
I hope my research holds true because I've always loved the sound, performance,and quality of the MBRP exhaust systems and I feel this one will also have a rich sound and the 3-4 added hp is all good !!! :idea:
RXONE,
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
MBRP silencer !!
Well here goes my report on the 1 month wait for what was suppossed to be a week waiting period !!
I finally got my MBRP silencer so I went straight to the garage for installation, checked out the crossover issue and yes this is a true X crossover design.
Did the exhaust system installation, damn those exhaust gaskets suck, should have ordered them a month ago it would have made the job much easier and for $12.00 a piece it's well worth the lack of aggrivation. I wish at least 1 YAMAHA shop around here would stock the damn things!!
After installation and before I hide the exhaust under the seat, I fired up the sled so that I could make sure the pipes were not leaking. The sled sounds OK, kind of a muffled quiet sound. Let's see how it runs on the stand ? Nice throttle response up to 1/4 throttle, anything above that will have to be tuned for the sled has alot of backfiring, coughing, and hesitation.
Alrighty then, let's finish the job, but wait the heat shield/ seat anchor will not fit back on over this new can !!! Left tailpipe is about 1.5" to far forward and the right tailpipe is about a 1/2" off in the opposite direction !
So I had to send it back, to bad because this was a well built and nice looking system and with some carb tuning it should have worked well !!! :roll:
I put my stock sytem back on and took the sled for a ride and it sure runs sweet in stock form. :wink: [/b]
