gregdec1
If I install a MC-X 180 kit on my Nytro XTX what else should I be doing to it. I plan on installing a 2 inch track with 8 tooth drivers and dropping down a gear on the top but not sure what clutching set up I should run. I live in Manitoba so its low elevation and want something that I can run on cheaper gas so thats why I chose the 180 kit.
FLYBYU
I think they offer a kit or the dealer your getting it from should point in the direction. I'd still premium fuel in it. Don't skip on the fuel or it will cost you more in the end with detonation.
Dimebag
Get the mcx primary weights and wrap your secondary spring at 90 degrees and your good to go. And gear down a tooth or two on top.
You can not run any lower octane fuel than premium.
Go for it. You wont be dissapointed.
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
- Sidewinder MTX 240 Tune Sidewinder XTX 240 Tune MountainMax SL 153.
No need for 8t drivers or noslip.
I got the 180 kit stock drivers 2" track 21-40 gearing.
Super rat weights 46-42 Dalton helix.
