2008FxNytro
- Oct 7, 2009
- Upstate, NY
- www.mpminc.net
sj said:the larger shaft is for higher...much higher h.p. applications...no issues just potentially stronger...
Ok, i figured that. just wanted to make sure people were not breaking them.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Do you recommend 8 or 9 tooth drivers for my Nytro RTX with 180 MCX - 144" backcountry 1.75 track and stock gearing ?
And the driveshaft is 1" hexagon, right?
sleddingfarmer
If you ever plan on running more than a 2" track, then 8 tooth is the way to go. But then you'd probaby want to go up a gear or two to make up for it.
Or if you wanted to run a 1.5" track with studs, go with 8 tooth drivers.
Otherwise just stick with the 9 tooth drivers. You'll have plenty of power with the stock gearing.
When you call avid to order the drivers they'll know the shaft size and everything.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Will there be enough clearance to the rail tips with extroverts, or do i have to cut them?
Thanks.
I don't plan on running any higher lugs than 1.75 , so then i'll stick with 9 tooth
Thanks.
sleddingfarmer
The RTX has plenty of room, no need to trim the rail tips.
The XTX is the model that needs trimming.
You are good to go!
You are good to go!
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Sounds good. Im getting the turbo installed next thursday, so I will order some extroverts after that.
I seriously can't wait
