kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
Sometimes I do but the stumble is mainly between 3 to 6/7000 rpm and is most noticeable in the lower part of that range. Throttle is crisp and clean up to about 3000 RPM.
Cruising is mainly 13/13.5 WOT is upper 11's low 12's.
You are right though it really is not an issue it's just that I know it's there, probably most wouldn't notice.
If I get back in to the map I will maybe try a little richer cruising AFR's
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Try adding fuel for that RPMs and the higher throttle positions, 60-80% throttle area. May help by adding more fuel faster when you open the throttle fast.
